Installing loader on 60 j.d.
rman
04-28-2003 19:57:06
we are installing a old loader on our 60 it came off a 60 got all hooked up run one set of hose to back of power trol and run return down at bottom of housing.where you drain housing. loader works ok but when you lower it it seems to pull tractor down abit is this normal.thanks for thr help rman.
Clooney
04-29-2003 03:16:53
 Re: installing loader on 60 j.d. in reply to rman, 04-28-2003 19:57:06
Rman, I guess I don't fully understand what you have hooked where?
~You say, " run one set of hose to back of power-trol"...How many hoses do you have hooked to the back & where are they hooked? ~You also said, run return down at bottom of housing, where you drain housing"
~Do you have more than 2 hoses hooked up to the tractor? If only one hose is going to the rear of the P/T valve where is it hooked & with what type of plug?
~It sounds like the rock shaft is trying to work at the same time as the loader so explain exactly what you have hooked where?
RMAN
04-29-2003 08:42:39
 Re: Re: installing loader on 60 j.d. in reply to Clooney , 04-29-2003 03:16:53
THANKS FOR REPLEY CLOONEY RT AND LEFT CYL HAVE TWO HOSES ON EACH RT AND LEFT CYL ARE TEE TOGETHER MAKING ONE CONNECTION ON REAR OF POWER TROL THERE IS TWO PLACES WHERE YOU CAN HOOK UP WITH QUICK COPLERS.WHEN RAISING WE HAVE IN TOP COUPLER WE INSTALLED OTHER TEE TO BOTTOM OF DRAIN ON POWER TROL IT WORKS GOOD UP BUT SEEMS TO PULL TRACTOR DOWN SOME WHEN LOWERING WE ARE USING ORIGNAL COUPLERS IN POWER TROL. THANKS FOR HELP MIKE
Clooney
04-29-2003 10:10:41
 Re: Re: Re: installing loader on 60 j.d. in reply to RMAN, 04-29-2003 08:42:39
RMAN, it sounds like the way you have it plumbed now the rockshaft is trying to raise when you lower the loader. Try moving the loader pressure hose to the bottom coupler. The rock shaft will just go up & stay up while the loader is working but won't try to pressurize when lowering.....
~Or use the proper [closed front] power-trol adapter [outlet coupling] in the lower P/T outlet & plumb the loader raise hose to that.
