Clutch noise 530
rman
04-17-2003 16:14:18
we have 530 that has a clutch whine or gear reduction whine when you drive tractor the higher gear seems like the more whine we have completely redonetrans and rear end new bearings and seals but this noise was there before. we filled reduction with new lube one thing noticed is some up and down play in clutch drum we also put new outer bearing on clutch drum clutch does seem to gett little hot when tractor is idling with clutch engaged thanks for any help. is this normal .also had gear reduction cover off and checked gears all looked good also new redution outer bearing thanks again mike
John Van Valkenburgh
04-19-2003 00:30:41
 Re: clutch noise 530 in reply to rman, 04-17-2003 16:14:18
The up/down play in the clutch drum is probably not a good thing but I'm guessing that it does not have anything to do with the whine. My 1953 model 50 has a lot of gear whine. Seems to be the 1st reduction gear. I hear it more under load, seems to be be in all gears. Don't hear it with the clutch engaged in neutral. Don't hear it as much going down hill.
I'm told this is fairly common. I believe the 1st reduction gear is straight cut making it more robust but subject to noise. I'd rather have noise than busted gears... I also look at it this way, with all that gear noise I don't hear the worn valve train as much!
John
ChuckW
04-17-2003 20:01:45
there have been previous reports on this same condition and I agree with them...the noise is coming from wear between the reduction drive gear and the transmission (large) drive gear. It seems that the gear teeth tend to wear flat and this causes the noise. My neighor has a 530 with the same noise....high pitch whine on advanced throttle...I have 2 520's and a 530 and they have slight whine.
