530 clutch fork adjustment
rman
04-01-2003 19:48:10
putting 530 back together replaced gear redution cover gasket found the two clutch fork stop bolts loose what is proper way to adjust these bolts 3/8 with lock nuts is size thanks in advance
Clooney
04-02-2003 03:03:54
 Re: 530 clutch fork adjustment in reply to rman, 04-01-2003 19:48:10
Rman, with the crankshaft end play set correctly [.005"-.010"], the clutch adjusted correctly, & the clutch released…Use a small pry bar & pry the pulley away from the engine to take the play out of the inner disk to the clutch driver, then adjust both stop bolts to have .060” clearance to the clutch fork stop pads…
