4010 d block
Jack-Iowa
09-30-2005 14:32:34
Just curious can a JD 4010 D block freeze and crack enough to allow the weep holes to leak water.Or would it leak oil as well? And I am assuming that it was full of water as if it was only half full there would be enough places for the water to go without exertng force on the block.
Make sense or not?
thanks
oops wrong board
09-30-2005 14:33:51
 Re: 4010 d block in reply to Jack-Iowa, 09-30-2005 14:32:34
oops
JMS/MN
09-30-2005 16:35:44
 Re: 4010 d block in reply to oops wrong board, 09-30-2005 14:33:51
Despite your oops...I think the leakage in the weep holes indicates bad o-rings on the liners. If not- it wouldn't be my first mistake.
RustyFarmall
09-30-2005 17:38:58
 Re: 4010 d block in reply to JMS/MN, 09-30-2005 16:35:44
Despite my handle I do know a little about the green tractors, and seepage from the weep holes indicates bad sleeve o-rings. Sounds like it might be time for a teardown and rebuild.
