I know that the size of the windrows is important, so maybe that already answers the question, but I can't resist throwing in another thought. I also have a 214WS, and at one point was getting slightly curved bales. Don't know if it applies to your 224WS, but... The obvious thing for me to try - being pretty much a greenhorn at this - was to play with the resistance adjustments. Looking forward from the back, the left side of the bales was a bit longer, so I cranked down a little more on the vertical pressure crank on that side. Now, that shouldn't make much difference since there's just the single channel pushing down at the middle with no side-to-side tilt, but after I did that, the bales were as straight as I could expect. It's also possible that the side adjustable resistor plates might be tweaked a bit - tighten up some on the side of the bale that's longer - or loosen the other side. I don't know these are answers, but easy enough to try and in my experience, it did the job. My most recent problem is that when I start up, I seem to break a few wires, then it seems OK for most of the rest of the cutting. The wires look like they are pinched too hard by the grippers, are weakened, then simply break at the pinch. Might try adjusting grippers a bit. If you've had any experience with that, I'd be interested. Also, on your 214WS, how do you get the knife on the plunger out to sharpen? On mine, the bottom bolt doesn't clear the side of the chute at any location that I can see to pull all the way out. The only solution I could see other than trying to sharpen in place with an angle grinder is to split the pitman bushing and slide the plunger all the way out the back. To do that, resistor plates need to come out, and not sure what else. Surely it can't be that hard! Any thoughts? Chuck, WA
