Farmall A #16 Sickle bar PTO?
Dan Ewald
06-25-2005 03:26:45
Hi - I need the front PTO section for a rear mounted Farmall A # 16 mower. Are they still availible or is there an adapter to use a modern PTO? I could always make something but if someone has the right one it would be a big help!
Thank's DAN
Dave H (MI)
06-25-2005 10:08:27
 Re: Farmall A #16 Sickle bar PTO? in reply to Dan Ewald, 06-25-2005 03:26:45
You just need the correct square steel, the PTO connector end, and a good welder. Fairly cheap to have fabricated. I did it with my JD #5.
Butcher
06-25-2005 08:55:34
Dont know about a #16 but for my #27 I went to Tractor supply. Bought the front section a little longer than needed and cut the square tubing to length.
Jason(ma)
06-25-2005 04:30:27
I've had some luck with implement parts from Fyre's in PA. Take a look through atis salvage yard list for the number, I don;t have it here at the house.
