Farmall - How can I find out exactly what manual I
vmax654321
05-05-2005 13:27:32
How can I find out exactly what manual I need?
I Just got a farmall,, It looks like the farmall cubs i see here [ i am completely new to tractors,, I bought it because I now have 3 acers to cut,, It runs good But when I drained the oil it looked like jet black soup... I decided I needed a manual to go further than a oil change...
can anyone tell me how to find out exactly what kind of farmall this is.,...??
JMS/MN
05-06-2005 11:03:04
 Re: Farmall - How can I find out exactly what manu in reply to vmax654321, 05-05-2005 13:27:32
Manuals generally come in three versions. The Operator/Owner manual tells you how to operate the tractor, lube it and simple maintence, along with identifying controls and simple adjustments on them. The Service/Shop manual tells you how to repair it. The Parts Manual ID's the parts and gives you numbers to order new ones.
Oliver
05-06-2005 07:22:49
Look at the Research and Info heading to the left of this page, then go down to Serial Numbers, and look it up.
old
05-05-2005 18:27:46
Post a picture here that goes a long ways. Also if its an old red cub the serial number should be by the steering shaft up front on the engine right hand side if your sitting on it.
vmax
05-06-2005 07:28:23
 Re: Farmall - How can I find out exactly what manu in reply to old, 05-05-2005 18:27:46
The tag reads:
Farmall
McKormic
SN 216677
PS: does anyone know what to set the timming at?
vmax
05-06-2005 07:11:55
The tag reads:
Farmall
McKormic
SN 216677
old
05-06-2005 07:17:53
 Re: Farmall - How can I find out exactly what manu in reply to vmax, 05-06-2005 07:11:55
That serial number puts it as a 1960 cub
vmax654321``
05-06-2005 07:24:06
 Re: Farmall - How can I find out exactly what manu in reply to old, 05-06-2005 07:17:53
thanks SSSOOO much..
Vmav654321
05-06-2005 07:27:43
 Re: Farmall - How can I find out exactly what manu in reply to vmax654321``, 05-06-2005 07:24:06
CUB Lo-Boy ?
CUB 185... ?
There are about a million manuals.. :-)
sory to be a pain...
old
05-06-2005 08:19:20
 Re: Farmall - How can I find out exactly what manu in reply to Vmav654321, 05-06-2005 07:27:43
That I can't tell you with out either a picture or some more info about it. Does it have a 3 point? What type/size engine does it have, 4 cylinder etc. What color is it? Also a picture goes a long ways telling what it is
