FORD front Blade on Ford 800?
SMARK
09-12-2004 12:49:18
Im looking at buying a Ford Dozer Front Blade for my 800. It has the controls and a hydraulic cylinder I assume to lift it up. It is large and very heavy looking. Its metal name plate reads FORD. The ad on the blade reads that it fits 8n,NA, 600&800. I would like some Idea on how well it works on a 800 and if I could use it to move dirt??
RWK in WI
09-12-2004 18:34:25
 Re: FORD front Blade on Ford 800? in reply to SMARK, 09-12-2004 12:49:18
If it has hyd. lift and bolts on to the bottom of the transmission it won't fit on an 8N but will work on the NAA and hundred series. ( The 8Ns took a cable lift and didn't have the transmission mount. ) If there are trip springs behind the blade it is set up for snow plowind and will only handle light dirt work or you can run a heavy chain from the top of the blade back to the frame to keep it from tripping. Those blades work well and are a good piece of equipment. I have one on a 640 and another on my 860.
