New Holland Square Balers - 268 or 273 ??
1st Timer
06-22-2004 21:04:02
Hi Guys....which one is better to use, both in fair shape and same price....advantages to either ??
JMS/MN
06-24-2004 22:20:13
 Re: New Holland Square Balers - 268 or 273 ?? in reply to 1st Timer, 06-22-2004 21:04:02
Does the 273 have the SuperSweep pickup? Measure the distance between the tines on the pickup- the SuperSweep would be narrower. For the same money and condition, plus the 273 is newer- the SuperSweep picks up thinner hay much better.
1st Timer
06-25-2004 03:39:21
 Re: Re: New Holland Square Balers - 268 or 273 ?? in reply to JMS/MN, 06-24-2004 22:20:13
Thanks for the info JMS/MN. Will do that
And thanks for responding Mike. I might do that also. What about manuals for these balers - owners/service/parts..... Where ???
Kelly C
06-25-2004 04:42:32
 Re: Re: Re: New Holland Square Balers - 268 or 273 in reply to 1st Timer, 06-25-2004 03:39:21
You can get manuals for NH balers from any NH dealer or you can call New Holland publications at 800-635-4913.
JMS/MN
06-24-2004 22:38:47
The 268 would also have only a two-joint pto drive. If the 273 has a three-joint pto drive, it will corner better and offset for a wider tractor. I switched my 268 to a drive from a 269 (only difference between the two) to get the three-joint. NH engineers (?) must have thought tractors were about 40 inches wide back then-(Measure the distance between the windrow pickup and the pto driveline)- When those balers were made, farmers planted corn in wide rows, but it takes a tractor set for 30 inch corn rows to pull that hay baler down a windrow without running over too much hay. Typical case of well-educated, well-paid people without practical experience, making machines for farmers to use. And yet, they made excellent haying equipment in so many other ways.
mike
06-24-2004 08:09:04
I might would try to buy both if i could afford it. If not buy the newer one if in the same shape. Both are pretty decient balers.
