Farmhand F-11 loader
Ron 1456
03-11-2004 04:46:34
What is a good Farmhand F-11 loader worth? This one has PTO pump, 5 ft. manure bucket, and 3rd valve. Has not been used much.
JD Doug
03-14-2004 23:29:31
 Re: Farmhand F-11 loader in reply to Ron 1456, 03-11-2004 04:46:34
Ron,
I own an F11 and love it. Best tool on the farm! Mine is dressed with the 5 ft manure bucket and grapple, I run it on a 2510 and wouldn't part with it for a million dollars (well, maybe...)
I spent alot of time researching it last year and if memory serves the grapple is worth $900 used and the loader with no attachements is worth $1,500. (in your case, the 5ft bucket would run about $250 used.) You should be able to get about $1,750 for the set up, maybe as high as $2,000 if everything is in good working order.
Doug
City Dude
03-11-2004 07:00:10
I bought a Farmhand loader awhile back and paid too much, I think. The PTO pump was missing and the joints were badly worn and the frame had extra welded on plates. 8' demountable bucket mounted on a dozer blade (looks factory) Paid $600 and had to fix leaking tilt cylinders. Took off oil tank and valves and used the three-valve setup on the IH4550. Big mistake. Very slow response. No float option on valves, so pushing snow is a chore of twiddling the valves. I should have bought a $300+ PTO pump and left the tractor hydraulics alone. For what my experience is worth ; 0
