4 bottom rollover breaking international 140
claude morrow
03-07-2004 18:27:35
would like to know what size hyd. cylinder is original to this plow,and also was this plow a good one,also how many horsepower does it require. THANKS
Hal
03-13-2004 19:54:32
 Re: 4 bottom rollover breaking international 140 in reply to claude morrow, 03-07-2004 18:27:35
I assume when you say a 4-bottom rollover you mean it has 4 bottoms up and 4 in the ground. With a plow like this it is not just a question of horsepower but the weight of the plow. You need a heavy tractor with a strong lift for such a plow. I would say 90-100+ horsepower minimum and front end weights. A FWD tractor you could get by a little smaller.
Hugh MacKay
03-08-2004 08:05:58
Claude: Do you mean 140 or could it be 540? Is this plow a semi-mount? If it is the 540 semi-mount either 3 or 4 inch bore cylinder will work. I liked the 4" best on 656 tractor as it made the raise and lower of the back of the plow just a bit slower, thus more even headlands. This will also be affected by the specific tractor and the gpm of it hydraulic pump. No problem for either cylinder to lift, it's all about timing.
Tim(nj)
03-08-2004 10:09:06
 Re: Re: 4 bottom rollover breaking international 1 in reply to Hugh MacKay, 03-08-2004 08:05:58
Hugh, I think he's got a fully-mounted rollover 2-way plow. Current CaseIH model is the 145. Probably wants to know what cylinder it needs to switch directions.
Hugh MacKay
03-08-2004 15:52:03
 Re: Re: Re: 4 bottom rollover breaking internation in reply to Tim(nj), 03-08-2004 10:09:06
Tim: you hit the nail on the head, I had forgotten about those rollover plows. Of course that is what he is talking about. I can't help him with that one. The only thing I know about an IH rollover plow is the right turning plow point use a left hand thread bolt and the left turning points use a right hand thread. The only reason I know this is partsman gave me right hand thread bolts for my semi-mount. I spent the day blessing him and tightening plow points.
