Farmall A Cultivators
John Elwell
10-04-2003 09:00:43
I have a Framall A Cultivision tractor and am trying to figure out how the cultivators attach to the tractor. It is a mechanical lift. If anyone has any pictures or diagrams, I would really appreciate the help as I am currently stumped. I can't even figure out which side of the tractor the lift handles go.
John (MA)
Hugh MacKay
10-04-2003 21:59:38
 Re: Farmall A Cultivators in reply to John Elwell, 10-04-2003 09:00:43
John: On the A with mechanical lift, I can't help you, other than to suggest you may go to photo gallery and type in Farmall A, you may get some pictures with cultivators mounted. If you posted this question on Farmall page there are several guys quite knowledgeable on these.
uglyoldfatman
10-21-2003 17:33:03
 Re: Re: Farmall A Cultivators in reply to Hugh MacKay, 10-04-2003 21:59:38
The lift arms go on the LEFT side.
I turned one over when I was about 16, and the lift arms are the ONLY thing that kept the tractor from rolling over on me.
I REMEMBER !!!
you have a square hole just behind the stearing gear box, that runs horizantaly. Your cultivators should have a square bar, about 1 1/4", that will slide into the hole.
Maybe this will help some. Sorry I do not remember more. Might be able to mount them if I was there, but not too good at remembering that long ago.
Good luck.
UG!
