JI CASE disc harrow durability/opinions.
02-05-2002 10:38:55
I am considering buying a CASE disc when I find one. I am talking about the pulltype angle iron frame discs on factory hydraulic and rubber tires. I know that compared to other makes of angle iron frame discs the Case's are heavier. What is your opinion on CASE discs? I am also wanting to find out the weight per blade on various sizes and the weight of the harrows altogether. Would you say that they are as heavy as the new square tubing framed discs in the same size categories built nowdays? Thanks
jal-SD - - - I don't have...
02-05-2002 12:24:56
 Re: JI CASE disc harrow durability/opinions. in reply to . , 02-05-2002 10:38:55
...experience with "newer" hydraulic lift Case discs, but when I was a kid, I didn't know that any company other than Case made pull behind discs until I was about 16. EVERYONE in our area had a Case disc, even if they pulled it with an IH, AC, JD, MH, MM or Ollies. Then our neighbor, a "died in the wool" JD man bought a JD. He later said he wished he still had his Case, as it was heavier, did a better job and didn't break like his JD did. He eventually traded for another Case & consoled himself by saying "Its green!" (My $0.02 worth. jal-SD)
R Wyler
02-05-2002 13:07:15
 Re: Re: JI CASE disc harrow durability/opinions. in reply to jal-SD - - - I don't have..., 02-05-2002 12:24:56
Thank you for the followup. I do agree the J.I. CASE is always the best.
Tim(nj)
02-05-2002 15:04:37
 Re: Re: Re: JI CASE disc harrow durability/opinions. in reply to R Wyler, 02-05-2002 13:07:15
The newest JI Case disks I believe were made by White, just before the merger with IH. One thing I'd check about the older Case disks is replacement bearing availability.
R Wyler
02-05-2002 16:59:22
 Re: Re: Re: Re: JI CASE disc harrow durability/opinions. in reply to Tim(nj), 02-05-2002 15:04:37
Thank you for the followup I did not know that White built the later J.I. CASE discs.
