New Holland 3pt Bar Mower ??
1755
04-09-2008 18:34:17
I have seen several of these on sails and usualy I cant figur out exacly how they work on the tractor they all look like there is part of it that goes under the draw bar and hooks up some how for the bar lift is something missing or am I looking at it wrong I have a 550 Oliver and it is set up like a Ford but no draw bar and a 880 that has a power traction hitch and the draw bar goes up and down with the 3pt I am trying to figur out if I can put one on thes 2 tractors thanks
paul
04-09-2008 19:49:15
 Re: New Holland 3pt Bar Mower ?? in reply to 1755, 04-09-2008 18:34:17
Typically there is a bar with ball sockets on both ends from the lower right side. The free end of this has a clamp on it that goes over the lower right lift arm and clamps on. As you lift the 3pt, the angle of the 3pt arm changes, so this bar lifts the far side of the mowerbar up.
A lot of times the top part of the clamp is 'missing' (probably in a bucket on the hayrack with other unknown parts....) and it costs like $50 to replace from NH.
The clamp is designed to fit a Ford lower arm. Might take a bit of tinkering to make it clamp onto other brands (fatter metal, or a brace or bracket in the way, etc.).
--->Paul
1755
04-11-2008 18:20:36
 Re: New Holland 3pt Bar Mower ?? in reply to paul, 04-09-2008 19:49:15
I know what you are talking about but this has another side to it it goes up the right side and down the left just like the part the toplink goes on thanks
