JD row disk???
BCnT
02-29-2008 10:38:52
i got a JD 2 row disk mounted on a tool bar...my dad always called it a row disk...not sure what proper name is...anyhow i got no use for it...its in good condtion except it could use a coat of paint...any idea what a fair price would be?
thanx
chuck
dobber
03-01-2008 09:33:22
 Re: JD row disk??? in reply to BCnT, 02-29-2008 10:38:52
Could be one modified for vegatable hilling or a pivot track filler.
http://www.bighambrothers.com/trackfiller.htm
Disc type bedders were popular in some areas also.
BCnT
03-01-2008 10:33:06
 yep...thats it... in reply to dobber, 03-01-2008 09:33:22
i'm almost positive mine has more than 2 blades per gang but same principle...my dad bought that thing years ago and told me to get it working...i never could figure out how to get it adjusted to make beds rite so i stuck it behind barn...it was all greased up and blades were like new last time i messed with it.
i guess i'll buy a qt of green paint and haul it to auction and try to swap it off for something i can use.
thanx
paul
02-29-2008 20:50:34
third party image
Hilling or bedding is not normal up here, but is it something like this machine? A hiller?
Link
--->Paul
BCnT
02-29-2008 23:04:19
 thats real close... in reply to paul, 02-29-2008 20:50:34
its got a single bar with 4 gangs that make 2 beds...if i get a chance this weekend i'll put it together and post pix.
thanx
johns48jdb
02-29-2008 18:38:47
never get rid of anything jd. somebody will want it. problem is that i don't have a clue about what your describing. can you go to implement photos and see if you can find something to match what you have. does it just have 4 big disk on it set at an angle.
BCnT
02-29-2008 19:14:15
 no,its not a disk plow*** in reply to johns48jdb, 02-29-2008 18:38:47
its more like described below
amo
02-29-2008 19:05:12
 Re: JD row disk??? in reply to johns48jdb, 02-29-2008 18:38:47
It sounds like it is 2 disc that throws dirt toward each other to make a bed to plant on.
BCnT
02-29-2008 19:19:19
 you got the rite idea... in reply to amo, 02-29-2008 19:05:12
i cant remember if its 3 or 4 blades per gang but they throw dirt up in a seed bed...i guess it could be used for cultivating too...i got a plow to make my beds with.
