Farmallb - easy way to set teeth on buzzsaw blade
Jerry Marks
11-13-2007 14:52:12
Farmallb - Check on eBay to see if there is a Buller sawset up for bid. They were made specifically for buzzsaw blades and make setting the teeth easy and you can consistently set the teeth to the same offset without any problem. You can usually pick one up for about $10, so they are not at all expensive. Hope this helps.
Jerry
