RC farms
4 bottom 16's
03-20-2007 10:20:08
I think I bought too much plow for my place. It's a 4 bottom with 16's, 3 point pull type, (no draw bar hook-up). This Orange booger must weight over 800lbs but is in excellent shape and the price was right $250. Still has the Allis stickers on it. I could probably take off the last two plows to save the guts on my Case 930, but I'm also concerned about pulling this plow with a three point...which is heavy duty but custom built by the previous owner. I have heavy clay and this 6 acres hasn't been plowed in 30 to 35 years...just disking. Any thoughts on this??
super99
03-24-2007 03:16:06
 Re: RC farms in reply to 4 bottom 16's, 03-20-2007 10:20:08
If it was me, I would try it before I started taking off bottoms. It's only 6 acres, put in 2nd gear and take off. Plow somewhere else first to get moldboards scoured and shiney and then go for it. Chris
Don-Wi
03-20-2007 23:50:20
Not familiar with Case tractor and i have no idea where you are at, but it takes all of our 105 HP Oliver 1855 to pull 4-16's in our soil. We probably could do with a smaller tractor, but it would just be too painfully slow to be worth trying. We pull 3-16's with about 75-85 HP.
Donovan from Wisconsin
Glenn F.
03-20-2007 15:00:30
Everyone's idea of heavy clay is different. We pulled 4-14's semi-mounted in clay with out 930 for years, but it was really too much for it. Sometimes we just had to lift the plow up a little. If you've gotwell established roots and indeed HEAVY clay, I don't think your 930's gonna do it. At any rate, you better have good tires full of ballast and at least 500# hanging on the front end.
Glenn F.
RC farms
03-21-2007 05:26:33
 Re: RC farms in reply to Glenn F., 03-20-2007 15:00:30
I live in eastern KS just a few miles from missouri. I would comnsider this real heavy clay. I have factory wheel weights on the back tires, but I was also thinking about dropping one of the plows off and using 3. Thanks for the point about the front weight.
RustyFarmall
03-20-2007 12:15:10
That 930 Case shouldn't have any problems with a 4-16s plow.
Allan In NE
03-20-2007 11:41:30
Hitches were built to pull. That's what they are on there for.
Allan
third party image
RC farms
03-21-2007 05:18:30
 Re: Hitches in reply to Allan In NE, 03-20-2007 11:41:30
The reason I was asking about the three point and draw bar is because my brother has a Ford 2 bottom plow that has the three point to lift the plow but it's actually pulled by a tongue on the draw bar. I didn't know if the 4 bottom would be too much on a 3 point.
tim[in]
03-20-2007 15:05:11
 Re: RC farms in reply to Allan In NE, 03-20-2007 11:41:30
even tho i'm an ac man . those are sharp looking tractors! of course i think the 60-70s tractor were all good looking.
RC farms
03-20-2007 10:24:05
 4 bottom 16's in reply to 4 bottom 16's, 03-20-2007 10:20:08
ok...it's Monday.
