F130 plow
kenny trimble
02-09-2007 19:18:54
im looking for a tail wheel assembly for my 3-point mounted f130 plow. this item is about impossible to find. does anyone know if i can use a wheel assembley from another model? if not does anyone have a lead on where i could get this item?? thanks!!!
kenny trimble
02-11-2007 15:01:22
 Re: F130 plow in reply to kenny trimble, 02-09-2007 19:18:54
i forgot to mention it is a john deere plow. im not sure of the year? thank you for any info!!! this is a GREAT forum!!!
Farmer Jack
02-10-2007 13:50:46
Try Kalsem Implement in Waterloo, IA
319-296-2236
MF Poor
02-10-2007 13:09:07
Just looked at a manual for Deere F130 plow. Tailwheel and associated brackets look to be same as what's on my 415A Deere plow. Should be same on a good many Deere plows from late 50's/early '60's. As far as I know, there wasn't a long landslide available for that plow. Same landslide on all bottoms.
Hugh MacKay
02-10-2007 07:01:33
Kenny: You say f130, you should also include manufacturer. This will be a fixed tail wheel on a 3 point hitch plow and as with most manufacturers likely all models of that make probably used the same tail wheel within a given era.
Personally, I wouldn't go for tail wheel on a mounted plow. These were designed for either tail wheel or long landside for the back bottom. The long landside will be far more beneficial in doing good quality plowing.
Leroy
02-10-2007 09:52:13
 Re: F130 plow in reply to Hugh MacKay, 02-10-2007 07:01:33
The long landside plows were never used in our area and from what I have seen I would want that tail wheel
