3180 woods bush hog
Fire Chief
01-17-2007 12:44:00
Need to remove clutch and shaft to replace the yoke. It looks like the yoke is made on to the shaft, how does this come apart? Thanks this is a batwing, it will be the right hand gear box standing behinde bushhog
Hurst
01-17-2007 14:24:28
 Re: 3180 woods bush hog in reply to Fire Chief, 01-17-2007 12:44:00
On our Woods B320 all the wing shafts and the main drivelne shaft, the yolks are welded onto the shaft and the only way to replace them is to replace the end you need with a WOODS shaft. When we did our batwing's main drive shaft, it was a 1 1/4" square shaft, a size not avalible aftermarket from our local aftermarket/Tisco dealer, so we had to go ahead and get the hole shaft. They are not as bad as you would think, or atleast weren't on our B320, Both were under 200, which for woods was a surprise to me. Good luck. I would check with the dealer first. The 3180 may be different, but I sure don't see woods taking a step backwards in specializing parts so you have to get them from them...
Hurst
