EzeeFlow bushings or bearings?
Gwiz
01-02-2007 15:58:42
Just pulled a 10 foot Model #100D EzeeFlow out of the ditch. Apparently someone lost it from behind there truck and broke the hitch off. Otherwise in pretty good shape.
I just noticed one of the beaters does not turn very well. Are these running on bushings or bearings? I haven't taken anything apart yet, but doesn't look like there is a bearing anywhere in the thing, including the wheels. They are very sloppy, are those just bushings too?
Thanks, if you've ever had one apart. If I pull the four square headed studs from the beater shaft, can I take it out?
James
