Transmix cement mixer
tj in iowa
11-26-2006 18:40:01
I aquired a Transmix mixer yesterday at a farm sale, it looks like most everything is there, but I played with it for 2 hours last night trying to put it on my MM Jet Star, and had no luck getting it figured out. It has a couple of extra angle irons on it too, maybe some one adapted it to a different tractor, or replaced old ones? If anyone knows anything about this let me know, thanks in advance.
Jim.UT
11-28-2006 19:46:41
 Re: Transmix cement mixer in reply to tj in iowa, 11-26-2006 18:40:01
third party image
third party image
I just sent you an email. I have more photos showing how to install this rascal. Without some hints, it's just a 200 lb Chinese puzzle!
tj in iowa
11-29-2006 10:27:34
 Re: Transmix cement mixer in reply to Jim.UT, 11-28-2006 19:46:41
Thanks a lot for the info, but I did not get an email, maybe you could send again, I would appreciate it
Jim.UT
11-29-2006 10:35:47
 Re: Transmix cement mixer in reply to tj in iowa, 11-29-2006 10:27:34
third party image
I just tried again. If you don't get an email from me through the YT system, check your spam filter. Maybe it's stuck there. Or you could click on my name and send me a message. Then I'll have your email addy and can send you the mixer info. My email is jwwebb1155 *at* aol *dot* com.
Here's another teaser photo.
the Unforgiven
11-26-2006 20:22:38
Hi tj, I have a Transmix mounted on an 8n Ford, it has a couple short pieces of heavy angle iron that bolt to the bottom of the axle housings, and a pair of small channel irons that hug the inside of the fenders. If it is for a Ford it will have no hook-up for a center link. If someone would post a picture I will send it to you.
tj in iowa
11-27-2006 10:26:39
 Re: Transmix cement mixer in reply to the Unforgiven, 11-26-2006 20:22:38
Thanks for the info, I will try putting the heavy irons on the axles and see if I can get something to line up, a picture would be nice if we could find one. Thanks
