Farm 4 wheeler
Lou
03-30-2006 07:50:54
Ive got 10 yr old Polaris 4 wheeler that I use for various jobs. Lately it isnt getting gas when theres plenty of gas in it. The dial that says Res and off seems to be goofy, can I bypass this valve ? cant seem to get it in the proper position so the gas is flowing. Thanks Lou
landlord7012
03-30-2006 15:52:48
 Re: Farm 4 wheeler in reply to Lou, 03-30-2006 07:50:54
I had a '96 Xplorer 400 and the petcock was goofy on that too. I never did figure out where reserve was. The pointy side of the dial should point to what you want right? Wrong! Just kept it full as possible.
There is an inline filter on there. The side covers can literally be ripped off (almost fainted when the dealer showed me that!) You could probably get away with something from Fleet Farm or an auto store. Also, that tank should be vented thru a hose under the triples (handlebar clamps). Check that by opening the gas cap and running gas out. If so, clear that breather line out.
Hope that helps!
landlord7012
Leland
03-30-2006 11:53:10
They make kits for them are you sure fuel filter is not needing replaced ? Also there could be a plugged screen inside tank also .
souNdguy
03-30-2006 11:41:48
i don't see why you couldn't pull the valve and install another that would have the same thread pitch.. or if it is too specialized.. just add an on/off tap, and remember that when it is empty.. it is empty..
You could also remove and clean it and see if it is simple to repair.. or replace with oem. knowing polaris.. it's probably a 100$ item!
Soundguy
Lou
03-30-2006 12:11:49
 Re: Farm 4 wheeler in reply to souNdguy, 03-30-2006 11:41:48
Im not sure of anything about this problem yet except they make these thing so you cant get at what any thing to fix it. Lou
