End Of The Line For My 1420 IH-Beware AF Owners!
1206SWMO
06-11-2006 19:07:01
Last Thurs eve 3 seconds after finishing the 2006 wheat harvest my 1420 IH did this.It broke the main axle housing in two.It did alot of damage and may not be worth fixing!!
In less than 5 minutes I would have been running 16 mph down the road which could have been disasterous!
All 1420-1440-1460-1480 Axial Flow owners beware.I would urge you to reinforce your axle housings as they were too weak from the factory.Lots have broken over the years.A friend takes one final off and drives another beam inside the original housing which is what I should have done.Since I didnt have a bin extension I thought I didnt need one.Wrong!
Gleaner R Series
07-09-2006 13:53:08
 Re: End Of The Line For My 1420 IH-Beware AF Owner in reply to 1206SWMO, 06-11-2006 19:07:01
1206 i admire you for fising up old combines and reusing them, and giving them another life. I have read a couple of your recent articles and it seems that you only have IH combines.....If you have more please list off what brand and model they are. I really hope you just dont have IH combines because we need to save all kinds of combines.
go 2388
06-18-2006 06:38:29
thay make them in Nebraska now.(2004 and up) I here that thay do alot better job makeing them there.
Nutsaboutcombines
06-11-2006 21:58:36
Blaine, I'm so sorry to see that. I DO hope you can get the 1420 repaired. I know you share my love for these machines and will not jut throw one away without carefully examining all viable options for keeping her alive.
Keep us posted.
1206SWMO
06-12-2006 20:25:03
 Re: End Of The Line For My 1420 IH-Beware AF Owner in reply to Nutsaboutcombines, 06-11-2006 21:58:36
I went to Cooks at Clinton,MO today and priced used parts.They have (3) 1420 and (1) 1620 IH parts combines.
I tore the combine down this eve and its fixable.Its going to take nearly $1000 worth of used parts and lots of hours of work to make it usable again.The sheet metal wont be very pretty as it was going to be over $400 just to replace it.I'll just straighten up the old the best I can for now.
the tractor vet
06-13-2006 09:19:08
 Re: End Of The Line For My 1420 IH-Beware AF Owner in reply to 1206SWMO, 06-12-2006 20:25:03
Also keep a close eye on the cab supports as i have seen two that the cab was fallen down from broken channels.
