John Deere 110 - snow blower?
Rock_Picker(MO)
05-15-2008 16:33:45
Just got my 110 running & having "way too much fun". Was wondering if they made a snowblower for it, how much one could expect to pay for one, and if the 8 hp Kohler is big enough to satisfactorily run one? happy putting.....RP
Timberoak 2119
05-16-2008 06:55:14
 Re: John Deere 110 - snow blower? in reply to Rock_Picker(MO), 05-15-2008 16:33:45
You did not state rather you had a early or late 110, the early 110 with the pan fenders takes a model 36 snow thrower and the later 110 with the fender deck takes a 37 or 37A snow thrower, the 37A is a better thrower as it does not cross the drive belt.
I had a 110 with the 36 thrower and the 8 HP did a good job most of the time.
I prefer a walk behind blower as it much more manuverable.
Any small tractor will require weights and chains
Rock_Picker(MO)
05-16-2008 19:14:57
 Re: John Deere 110 - snow blower? in reply to Timberoak 2119, 05-16-2008 06:55:14
My tractor is a 1974 model..... .thanks for the info..... ..james
chevy65
05-16-2008 04:33:07
What you need is a 37A snowthrower
You will also need the front lift if its not already on tractor
Good Luck Gary
Max(ia)
05-15-2008 17:04:44
I"ve got a Snowthrower for my 8hp and get along just fine during the Iowa winters also have one for my 10hp. Deep wet snow can cause problems, that"s the problem with a thrower over a blower. A good one would probably cost around $200 around here.
