John Deere 111 electrical issues
Ken B2
04-24-2008 21:42:52
I"ve had to replaced the battery a couple of times in the last couple of years, but now even with a relatively new battery it won"t start without jumping it. When I jump it it start and runs fine. However, with the engine running, if I flipped on the PTO the engine would quit. I then discovered that if I flipped the PTO with the jumper cables still attached I could get the blades going and the engine wouldn"t quit and I could cut my lawn. Now, however, when I try to remove the jumper cables with the blades on they will immediately cut out. Any imput would be greatly appreciated.
chevy65
04-25-2008 04:34:04
 Re: John Deere 111 electrical issues in reply to Ken B2, 04-24-2008 21:42:52
Problem is is the charging system isnt working
111 has a low output charging system
The system has a charging stator under flywheel and a diode in the wiring
Most likly the diode is burnt out
2 different styles were used Most common was a diode in a short red wire
Follow the single lead from under flywheel to find diode
usually a red wire with eyelet hooked to positive side of starter solenoid
Some unit had a diode module A square box under battary box
Battery box removal will make tracing wires easier Good Luck Gary
