homelite
ralston
04-24-2008 06:25:39
i got a old homelite chainsaw an the engine is locked up does anyone have a sujestion on how to free it up
El Toro
04-24-2008 11:22:39
 Re: homelite in reply to ralston, 04-24-2008 06:25:39
I freed up one with ATF in the cylinder. Had it for years and never pulled the engine apart. Hal
Old Roy agiin
04-24-2008 10:18:00
"jb puller" is right about that might be the problem.My son gave me one said it was blowed up, it was locked tight. I just figured he ran the wrong gas. and I might use it for parts,layed on shelf for a yr.or so Gave it to a neighbor, he had it running in 20 min. [stick in flywheel]. That's all for this episode of "dumb and dumber"
les_from_syracuse
04-24-2008 09:38:10
Take the plug out and check that the cylinder isn't filled with oil.
jd b puller
04-24-2008 06:33:43
 Re: homelite in reply to 84261, 04-24-2008 06:25:39
If the engines truly "locked up" from siezure, you're going to need a new jug and piston. Probably not worth fixing. Make sure it's actually locked up and not something stupid like a stick in the flywheel or something.
