importance?
redbone
04-03-2008 07:32:41
In your opinion, just how important is a fuel filter on a garden tractor?
Thanks
Redbone
Leland
04-03-2008 22:14:21
 Re: importance? in reply to redbone, 04-03-2008 07:32:41
Just as important as using a condom on a woman you meet in a bar .Filters have saved many a man .
William Pearson
04-03-2008 14:25:45
You can answer this question your self by pulling down a float bowel on a carburetor that does not have a fuel filter.
Bill in Richmond, Va.
Kentb of SWMO
04-03-2008 13:08:31
If you are talking the little round one like many B&S engine have on them, My oppinion of them is the will stop a Holstein cow but not a Jersey.
Kent
IH2444
04-03-2008 09:37:25
I put fuel filtwers on all my shall end=gines that I can put them on. Between that and using gas stabilizer I almost never work on a carb.
El Toro
04-03-2008 08:05:47
I did have to change the fuel filter since it did such a good job of filtering. The engine lost power when mowing and a new filter fixed the problem.
El Toro
04-03-2008 08:03:12
I would keep using one. Hal
PS: I haven't had to clean the carburetor in 37 years. Just plowed the garden with it last week.
R Bedell
04-03-2008 07:54:49
 Re: importance? in reply to JT, 04-03-2008 07:32:41
I personally use one. I have found, that if you use the correct type, it prevents foreign material from getting into the Float Valve Seat and prevents clogging the Jets. Just my two cents worth.
