bad switch?
redbone
02-09-2008 17:27:17
I have a 1968 Wheel horse commando 8. I recently had all new wires and a new coil put on it. It starts and run fine, but when you cut the switch off, the engine keeps running. The only way to shut it off is pull the plug wire, and my fingers are getting numb from too much of that.
What do you think? Bad switch? I replaced that also a few months ago.
Thanks
Redbone
joe csuti
02-12-2008 17:05:25
 Re: bad switch? in reply to redbone, 02-09-2008 17:27:17
What type of ignition system is on eng-mag with points or 12 coil with points?
Redbone
02-11-2008 12:06:36
I should add that at first, right after I installed the new switch, coil, wires, etc., Everything worked fine. Then about the third time I cranked it I couldn"t cut it off.
Redbone
El Toro
02-13-2008 05:15:22
 Re: bad switch? in reply to Redbone, 02-11-2008 12:06:36
Check the switch. Hal
El Toro
02-10-2008 08:16:21
If you have battery ignition your switch may not
be stopping the battery voltage to the coil.
You can check this with your volt meter at the switch to see if voltage is present to the coil
when the switch is in the off position.
If its an armature (coil) your switch may not be grounding out the armature. You should be able to check that with multi-meter set on Ohm's.
Hal
steve from mo - dangit!
02-09-2008 18:23:36
You would want to make sure that you have the correct wiring harness and switch for your tractor. The magneto units are different from the battery ignition units.
