how to polarize Starter generator
ldj
02-06-2008 17:59:59
How do you polarize the Delco Remy S/G on a Cub Cadet 149?
R Bedell
02-07-2008 11:23:55
 Re: how to polarize Starter generator MORE??? in reply to Dale I, 02-06-2008 17:59:59
The "L" terminal was used on early Cubs and it was designated as "Load".
The correct V/R for 149 is IH-545130-R92
El Toro
02-07-2008 07:07:17
 Re: how to polarize Starter generator in reply to ldj, 02-06-2008 17:59:59
I have a Delco starter/generator on a Wards tractor made by Gilson and I have never had to polarize it since I bought it new in 1971. I've had the generator off several times to replace the
brushes and since I have a spare generator I install it and do the brushes later. The regulator is buried inside the frame and is just
about impossible to get to. Never had a charging problem in 37 years. Hal
joe csuti
02-07-2008 03:41:19
Sorry,had wrong website in mind,goto link below in addition to link posted by r.bedell.
joe csuti
02-07-2008 03:14:03
Go the extra step & polarize regulator only takes 2 sec,this way you'll be sure,momentraily touch a jumper between B & A term on reg,any time you open wiring on s/g & reg you lose residual magnetism in pole pcs in s/g,if you have a bad reg s/g will not charge,you need the residual in pole pcs to start charge function,if you haven't gone to link from r.bedell do so & read/print sections on s/g and 2 & 3 pole reg as to how s/g & reg function & work together.
Bob
02-06-2008 19:00:18
Actually, every time you use the starter function, you polarize the generator function.
ldj
02-06-2008 20:56:52
 Re: how to polarize Starter generator in reply to Bob, 02-06-2008 19:00:18
Are you saying it is not necessary to go to the separate step to polarize the S/G ?
R Bedell
02-06-2008 18:29:55
 Re: how to polarize Starter generator in reply to Dave Hammer, 02-06-2008 17:59:59
Click on this link....Look towards the bottom of the page: S/G
ldj1002
02-07-2008 09:58:19
 Re: how to polarize Starter generator MORE??? in reply to R Bedell, 02-06-2008 18:29:55
Thanks all. I think I may have a voltage regulator than isn't what it should be. Looking at the wiring schematic for CC 149 it has 3 terminals, Bat., Gen.,and f, all on 1 side. My regulator has F, Bat, and L all on one side and on other side and underneath there is a gen. terminal. What is the L terminal? will this regulator work if I wire it and disregard the L terminal and follow schematic for the Bat., gen., and F?
ldj1002
02-07-2008 10:16:08
 Re: how to polarize Starter generator MORE??? in reply to ldj1002, 02-07-2008 09:58:19
I just look at more wiring schematic and it looks like CC 100 and below has VR like mine. So I assume I can follow that schematic?
