any simplicity walking tractor experts out there
Cranbrookcub
01-08-2008 10:43:44
I have a couple of these walking tractors, I found with rotted motors. I have recently put a honda 5 hp engine on one and ran it to push snow, it pushed great, like a tank but I didn't like how I could not change gears because the belt idler did not release tension all the way, is there a trick to setting up the belt off the engine to the tranny so it won't run when the idler is released. Is there a place i can get pictures of the tratcor to determine if there are parts missing off this system ?
Has any one every tried or thought of using a go cart clutch on these machines, ?
steve from mo - dangit!
01-09-2008 10:02:21
 Re: any simplicity walking tractor experts out there in reply to Cranbrookcub, 01-08-2008 10:43:44
Simply: You"re supposed to have a couple of guards to hold the belt so it hangs loose from the engine pulley. Without the guards, gravity will leave the belt in the pulley groove. If you can remember how the old engine was set up or can find a detailed picture of the correct setup you"ll be good to go.
Karl Brandt
01-08-2008 15:53:45
What model of Simplicity tractor do you have?
Check out my website for more information on these Two Wheel Walking Tractors.
I have a model chart on these tractors...with specs and other information.
Karl
perry in mi
01-08-2008 12:46:34
try over at simpletractors.com
perry in mi
01-08-2008 12:56:37
 Re: any simplicity walking tractor experts out there in reply to perry in mi, 01-08-2008 12:46:34
direct link
