cadet rearend
ira biggs
01-01-2008 12:40:38
i have a cadet rearend i need to know witch cadet it was for, it has the internal brake on the left side. other than that not much else. some casting numbers. but no cub cadet serial number tag. thanks for any help
Dustin hartmann
01-03-2008 05:08:10
 Re: cadet rearend in reply to ira biggs, 01-01-2008 12:40:38
Its from a cub cadet original the only ones with enternal brakes on one axle on the left side the serial # should be on the right side stamped in the case
ANON
01-02-2008 16:33:21
tompepper is correct, if it has a brake on the left axle housing, it is from an Origional. There should be a number stamped in the right side of the reduction drive housing.
R Bedell
01-01-2008 16:34:56
Ira Biggs:
Internal Brakes were used on Cubs from the 1x2/3 Series all the way through the 82 Series.
Perhaps a picture of what you have, can narrow it down...third party image
JT
01-01-2008 14:42:37
What is the casting numbers on it? Post a picture, that will help a lot.
Jim
ira biggs
01-01-2008 13:16:21
i have a 122 , 102 , and a 128 and this reaeend looks like none of them. thanks again
skip176
01-01-2008 13:08:24
If it got internal brakes its likly from 102 122 124 It should work on any of the narrow frames. Some one told me to swap my 106 for one with the internal brakes as they work better than the disk brakes.
Hope that helps
tompepper
01-01-2008 16:14:57
 Re: cadet rearend in reply to skip176, 01-01-2008 13:08:24
with the single brake on the left side it sounds like its from an original cub cader 1961-1963
