international cub cadet 127 hydro
vac 54
10-20-2007 20:48:15
has kohler engine model/k3014 #2049753 spec47376b someone took carb apart cant find parts. carb IS E235058 # BELOW MOUNTING FLANGE.can some one help thanks
Kentb of SWMO
10-21-2007 14:47:01
 Re: international cub cadet 127 hydro in reply to vac 54, 10-20-2007 20:48:15
Go to a cood Kohler dealer and he can order you all of the parts you need.
Kent
skip176
10-21-2007 05:30:59
I dont under stand what you need. I have a couple of carbs here that have stuff missing off them. If you can send me a pic or post one and show us what you need I might be able to help you out with the parts.
Bob
10-20-2007 21:04:14
Do you mean K-301?
What parts are you needing?
vac 54
10-21-2007 07:13:38
 Re: international cub cadet 127 hydro in reply to Bob, 10-20-2007 21:04:14
just checked model # it is K -301A I NEED COMPLETE CARB KIT PLUS, POWER JET, FLOAT.BOTTOM PART OF CAB THAT COVERS FLOAT AND THE NUT TO HOLDS IT ON. OR A COMPLETE CARB THAT WILL WORK THANKS.
