briggs updraft carb
James Duncan
09-09-2007 02:27:46
hi. I have an old Craftsman/Case Custom 7 lawn tractor with a 1974 Briggs #190402/0657-1 engine. Have rebuilt the old updraft carb and have a problem with the engine bogging down when the mower is engaged. Get black smoke for a couple of seconds when this happens then it smooth's back out. This leads me to think it's not enough air. 2 fuel adjustments on the carb, Valves are ok,compression good, what is my aged feeble brain forgetting?
joe csuti
09-09-2007 17:27:40
 Re: briggs updraft carb in reply to James Duncan, 09-09-2007 02:27:46
If you're getting black smoke from exhaust your hi-speed needle is probably set too rich,also when adj needles you must get hi-speed end set for max rpm & smoothest running before setting idle needle,there's an inter-action between them.If after adj carb you still get black smoke I would suspect weak or streched spring on gov linkage or a misadjusted gov/carb linkage.
shannon from ohio
09-09-2007 17:16:33
Air bleed plugged -or- bent/damaged main nozzle (Make sure to remove main nozzle BEFORE bowl dissasembly OR it WILL be damaged!)
Bills1450
09-09-2007 08:44:55
Seems odvious but is air cleaner good and clean.
James Duncan
09-10-2007 19:34:26
 Re: briggs updraft carb in reply to Bills1450, 09-09-2007 08:44:55
Bills. Well DUH! I think you may have nailed it. While I was running in 10 different directions trying to think of something complicated. Said my mind was feeble didn't I. Will try that little thing first thing tommorow. Thanks guys. "walks off smacking self in the forehead" Allen
Dannie
09-09-2007 03:45:03
Check the springs that control governor.
