briggs engine
sojono
09-02-2007 19:26:40
i have a 3410 simplicity 10 hp engine 243431 does anyone know where i can find parts to rebuild engine thanks sojono.
amertrac
09-03-2007 11:37:38
 Re: briggs engine in reply to sojono, 09-02-2007 19:26:40
if it runs decent only smoker try useing 30 wt non detergent oil .i use non detergent in all aircooled engines new or old have had very few problems . right now my youngest yard machine is a 1952 massey harris oldest is 1947 bob w.
El Toro
09-03-2007 08:16:02
I would do as Joe suggested and having the block and crankshaft measured. Parts are becoming scarce and I think B&S are almost forcing everyone to buy their newer engines. I did an old B&S model 23 9hp engine and it ran fine, but smoked. I stripped the engine and took it to our local auto machine shop. They said it needed to be bored .020" os and the rod journal need to be ground .020" undersize. Parts were available from B&S. I still have this engine on an old Toro Grassking. Still runs great.
You can run off a parts list on your engine off the internet. You can call them for one too at 1-866-436-7387. You will the type # from your engine. Hal
david pierce
09-03-2007 07:13:27
A friend and me just brought out a lawn mower shop with a lot of old briggs parts we have about 10 or12 sets rods,rings.piston and gaskets you can email me tractor39n@yahoo.com with model munber and I'LL see if I have anythang you need thanks Dave
Wrench Spinner
09-03-2007 06:14:06
You can check part availability below, Enter your model and type numbers then download the IPL then enter your selected part numbers.
joe csuti
09-03-2007 03:53:06
This is an old cast iron eng,a lot of the parts for same may be "no longer avail",the best thing you could probably do is disassemble eng & take block to a machine shop & have cyl checked with a bore gage or inside micrometer to find out if you can get away with a std set of rings & piston or have to go to an os set & have eng bored(.010 set listed as nla from briggs,but may be avail as aftermarket)and then take it from there as to what parts are still avail for eng,maybe El Toro will read this and pick up on & can offer a source of parts as I believe he has rebuilt several of these or similar eng,you might also check on ebay in outdoor power equip,multi use eng,briggs,there are several guys there that sell rebuild kits or put together a custom kit for your needs,you would have to look at ad's and ask seller a question if he could make up a kit for your eng.
sojono
09-03-2007 10:09:13
 Re: briggs engine in reply to joe csuti, 09-03-2007 03:53:06
thanks guys it still runs good but it uses oil and smokes i wanted to find parts source before i tore it down my friend ask why it was smoking i told him i was fumigating my yard thanks to all replys.
El Toro
09-03-2007 13:17:08
 Re: briggs engine in reply to sojono, 09-03-2007 10:09:13
Just check your oil frequently. Hal
