is an 18 hp kohler from a cub cadet interchangeable for a 1
Dustin Leistra
06-26-2007 14:41:15
yes just wondering if i could swap out the 16hp kohler on my allis chalmers 916 hydro for an 18hp kohler off of an cub cadet should this be an easy swap any info is greatly appreciated
JT
06-28-2007 06:54:25
 Re: is an 18 hp kohler from a cub cadet interchangeable for in reply to Dustin Leistra, 06-26-2007 14:41:15
one issue will be as to what model engine you are taking out and which one you are putting in. If you are taking out a K Series, it is a battery ignition, if you are putting an 18hp twin magnum, that is a magneto ignition, so you would have a wiring isssue to resolve. And if you run any of the attchaments on your tractor, you might have c/s size issues.
Leland
06-26-2007 19:48:18
I don't know why just make sure the shafts are the same ,I don't know if you will need new hole in the frame to mount .
