i hope its not bad...
redbone
06-08-2007 11:41:29
hey guys i took the fuel pump off my wheel horse engine to see about cleaning gunk out of it, according to the kohler manual online for this engine(K181), there is supposed to be a lever that rides the cam to work the fuel pump. when i took it off, no lever to be found. maybe it broke off inside the motor? if so, could i just get a new fuel pump and mount it or will the broken lever(if it's in there) bounce around and cause damage?
please help.
redbone
here's the link to the diagram, page 28 of the pdf file.
http://www.kohlerengines.com/common/resources/tp_2379.pdf
2cents
06-08-2007 16:43:16
 Re: i hope its not bad... in reply to redbone, 06-08-2007 11:41:29
my K181 in my WheelHorse B-80 Has the Lever on the Pump, But I understood Most dont, Better to be safe than sorry.
El Toro
06-08-2007 13:10:49
You can go to OPEengines.com and you may see your pump. Hal
PS: If it has a lever I would look for it.
redbone
06-08-2007 13:31:47
 Re: i hope its not bad... in reply to El Toro, 06-08-2007 13:10:49
thanks a lot. thats a great website, went onto my favorites list.
I am very relieved to find out that my fuel pump IS vacuum and i dont have to go digging around my engine for a broken part. sorry for all the post with questions but i'm learning.
thanks everybody.
JT
06-08-2007 12:39:30
most Wheel Horse tractors with K181 engines use a vacumn pump, that is why they is not pump lever on the pump. They use 2 diffeant pumps, so just because the service manual shows a lever, does not mean there is supposed to be one.
Jim
redbone
06-08-2007 13:01:10
 Re: i hope its not bad... in reply to JT, 06-08-2007 12:39:30
i hate to ask this but are you sure? not that i dont trust you but i really dont want to screw something up. the pump was mounted on the engine where when i took it off there's the cam inside there. i am going to have to go into the engine eventually, it's leaking oil around the base, guy said it had a tick in it when it ran.
i took off the head and when i turn over the flywheel, the valves raise up fine then seem to snap down a little , then return closed. maybe the guides are worn?
thanks again, just trying to get it running and see where i'm at.
JT
06-09-2007 07:54:03
 Re: i hope its not bad... in reply to redbone, 06-08-2007 13:01:10
What is the spec number on your engine, and then you can find out for sure.
Jim
redbone
06-09-2007 08:14:48
 Re: i hope its not bad... in reply to JT, 06-09-2007 07:54:03
spec # is 30108. thanks
JT
06-09-2007 18:19:09
 Re: i hope its not bad... in reply to redbone, 06-09-2007 08:14:48
Yep, your uses a B-231390-S vacuum pump, so you have not lost an arm, that is the way they are built on a K181S-30108 Engine. so breathe easy, you don't have to go fishing for an arm, it was never there
Bob
06-08-2007 12:32:11
I wouldn't leave it in there.
You MIGHT snag it with a magnet, or else drop the engine base.
The connecting rod has a "slinger" or "dipper" that throws oil around, which will probably "whack" the lever sooner or later.
Actually, you'd better have a look in there to see if the "dipper" is intact.
