a general question
redbone
06-07-2007 11:13:36
i have a decision to make. the carb on my 1968 wheel horse commando needs cleaned and rebuilt or replaced. there is a carb kit at M&D for $30, a new carb's gonna run over one hundred bucks.
this carb is gummed up pretty bad, you can smell the old gas reeking from it.
What do you think? clean and rebuild (and pray) or stay safe and fork over big buck$ for a new carb.
thanks, redbone
redbone
06-07-2007 18:29:51
 Re: a general question in reply to redbone, 06-07-2007 11:13:36
thanks guys for alerting me to the ripoff. Usually M&D is reasonable. I went onto jack's small engines site and ordered one for $7, going to try to rebuild it, not really sure what to do but i need to learn and got to start somewhere. plus i found the engine service manual free on kohler's webite. 8 pages on carb alone. what a find.
thanks again guys.
redbone
oldrustycars
06-07-2007 17:13:15
if the body isn't warped, and the throttle shaft doesnt wobble in the bushings, it should be rebuildable with no trouble.
William Pearson
06-07-2007 16:45:46
What all comes in this carburetor rebuild kit? Check the float to make sure it does not have a hole in it and the mounting ears for being warped on the carburetor. How you spend the money is a matter of how comfortable you feel about your rebuilding capabilities. A 100 bucks is cheap if all you have to do is bolt the carburetor up and adjust, but if rebuilding a caburetor is just another day to you (or you want to learn how) then buy the kit.
Bill in Richmond, Va.
bo
06-07-2007 15:33:55
strip it down to it's basic elements...get some liquid and spray B-12 from Walmart or where ever and remove all the rubber and plastic parts, soak, spray, blow out with compressed air and it'll be good to go.
BUTCH GA.
06-07-2007 13:35:36
I paid 12.65 for mine from John Deere for my kohler
JT
06-07-2007 11:47:59
$30.00 for a Kohler car rebuild kit is robbery, they sell for less than $12.00
