help on wisconsin eng.
larryinwa
05-27-2007 14:29:19
have a 10 hp wisconsin tra-10d-governor won't govern-took housing off gov. gear is ok but is only running on very edge of the cam shaft gear-there is a grove on the shaft that the gov gear rides on that looks like it might have a snap ring to hold gear out more -should there be one? also anyone have drawings of linkage from gov cam on the outside to the carb? tra-10d-spec#285633-serial#5013978.thanks for any help.
oldrustycars
05-28-2007 16:49:53
 Re: help on wisconsin eng. in reply to larryinwa, 05-27-2007 14:29:19
If no one here can help, theres usually lots of Wisconsin manuals on eBay. If you're going to own a fine Wisconsin engine, you should own a manual.
