big or small problem?
daniel in sc
05-16-2007 15:56:04
on the tecumseh i"ve been working on(TVS-90), when i took off the cylinder cover the camshaft fell out before i could align and mark the gears where it meets the crank. so my quetion is will i ever be able to get the timing right again?
the reason i tore it down in the first place was to replace rings. the piston has minimal wear on the outside but no visible scoring in the cylinder so as soon as i measure for out-of-roundness i guess i"m good to go?
there is an old gentleman who might be able to help me. he used to have a small engine repair business, now retired, but he"s in his 80"s so i better hurry.
there i no deadline on this i have all the time in the world so long as money holds out. but if i can"t ever get the timing right again i may be finished. any ideas? thanks.
Dannie
05-17-2007 01:00:32
 Re: big or small problem? in reply to daniel in sc, 05-16-2007 15:56:04
Align the dot & dash 1 on crank other on cam or on some align gear keyway on crankshaft beveled tooth withcamshaft timing mark in front of small hobbing hole.Good Luck
El Toro
05-16-2007 16:25:25
Have you looked for any punch marks on the gears?
There may be .. on one gear and just . on the other. Hal
