is it sheared?
daniel in sc
04-27-2007 14:13:25
ok i tried to load the image on this message but all i got was the little red 'x' so i put the picture in the 'garden tractor gallery'. could someone please tell me if this is the flywheel key and if it is sheared and causing hard starts. i'm new at this kind of thing. thanks for your help.
JayPhillips
04-27-2007 19:10:49
 Re: is it sheared? in reply to daniel in sc, 04-27-2007 14:13:25
Daniel,
Let me guess....the blade has been removed. If so....that's part of the problem. I believe that the blade acts as a rotating mass. At least I know that's the case with Briggs & Stratton engines using light weight aluminum flywheels. If the mass is removed....it'll snatch the starter rope right out of your hand, shear keys, and eventually bust the starter rope and/or handle at shut down.
Good luck,
Jay
Jim K
04-27-2007 18:56:12
Is that the way you found it or did it inadvertantly get flipped over?
If so flip it over and see if it runs better I don't believe it is sheared.
Andy Motteberg
04-27-2007 18:49:32
Remove the flywheel with a puller and see i the key somes out in two pieces. Andy.
joe csuti
04-27-2007 17:50:17
You replaced float in carb-Did you set float level & drop? you may be flooding eng & hydro locking piston in cyl,if carb has hi-speed needle on bottom of bowl close finger tight & reopen 2 turns,this should get you in ballpark for starting,if eng still jerky after this,close hi-speed needle,disconnect fuel line from carb,remove spark plug crank eng over 10-15 times,replace plug,crank eng 8-10 times to see if it gets jerky,if it does get jerky it's a mech problem in eng,if not reopen needle on carb,reconnect fuel line,try to start,if jerkyness returns,problem in carb.
Bob
04-27-2007 14:42:21
Third Party Image
Tecumseh uses weird offset keys like that.
ASSUMING that is the right key for that engine, it does NOT appear to me to be sheared. I'm sure others will chime in with their opinions.
