backfiring
skubbs
04-06-2007 10:18:05
Kohler K321. Got spark, fuel. Won't start. When I put a bit of gas in the spark plug hole, or spray a bit of starting fluid, it only backfires. Suggestions, anyone?
Thanks,
Steve
Kent of SWMO
04-07-2007 10:02:11
 Re: backfiring in reply to skubbs, 04-06-2007 10:18:05
Is this engine a magneto or battery ignition? Spark plug should be a H-10C Champion gapped a .025. If the ignition is battery CHECK to make sure you have the coil polarity right.
Kent
skubbs
04-07-2007 20:46:24
 Re: backfiring in reply to Kent of SWMO, 04-07-2007 10:02:11
I believe it is battery. It has points, condenser, coil, solenoid. Strangely enough, I can"t find in the engine service manual the right polarity for the coil. I just copied how another Kohler engine is set up.
Can you offer advise in this area?
Thanks, Steve
El Toro
04-08-2007 07:26:21
 Re: backfiring in reply to skubbs, 04-07-2007 20:46:24
If your battery is negative grounded the small wire from the small negative terminal on the coil
should go to the points. Hal
traper
04-06-2007 18:25:48
Skubbs//Check point gap if too wide will cause problem you have 20 ths. or match book cover.
skubbs
04-06-2007 13:27:26
I've had the plug at .025 and .035...the service manual calls for a .035 battery (?) gap. I've never seen the engine run. The guy I bought it from said he used it, and it ran fine, but he couldn't get spark. I got spark, but still no run. I'll have to check into the timing.
Thanks
El Toro
04-06-2007 15:07:59
 Re: backfiring in reply to skubbs, 04-06-2007 13:27:26
Does that engine have that compression release? It may be holding the valve open. Hal
skubbs
04-06-2007 17:36:59
 Re: backfiring in reply to El Toro, 04-06-2007 15:07:59
Yes, the service manual says it does. Sounds like I might be learning the inside of a Kohler.
El Toro
04-06-2007 18:52:03
 Re: backfiring in reply to skubbs, 04-06-2007 17:36:59
My B&S manual shows an arrow on the flywheel and an another arrow near the armature that need to be aligned for the timing. Kohler may something similar. Hal
El Toro
04-06-2007 11:16:01
It sounds like the timing may be off like a woodruff key may be sheared slightly. Are you using the correct sparkplug for that engine and gapped at .025"? Did it ever run before since you've had it? Hal
skubbs
04-06-2007 13:55:36
 Re: backfiring in reply to El Toro, 04-06-2007 11:16:01
I thought I already replied. Oh well. I've never seen it run. Previous owner said it ran well last year, but could get no spark this year. I got spark, but now this problem. I've gapped the plug at .025 and .035, tried two different new plugs, changed the plug wire.
To set the points I turned the engine till the points were open fully, then used a feeler gauge to set them to .020. That's their max opening.
How do I check the timing?
Thanks,
El Toro
04-06-2007 16:28:49
 Re: backfiring in reply to skubbs, 04-06-2007 13:55:36
I don't have a shop manual on Kohler engines, but I do on B&S engines and it has the procedure in there for those engines. Some of the people that post here may have a manual with the procedure. I can post a copy of the procedure for the B&S engines if you want to see it. If you have a Kohler dealer in your area he should be able to zerox you a copy. Hal
PS: I would bring the piston to TDC on the compression stroke and see if both valves are closed.
skubbs
04-06-2007 17:39:59
 Re: backfiring in reply to El Toro, 04-06-2007 16:28:49
I have the service manual...will have to read about it. I was hoping to check the timing from outside the engine.
