j d 212 mower
in sticks
12-27-2006 06:29:43
on a jd 212 when you engage the electric clutch for the mower deck the amp goes to discharge side of guage.when NOT using deck the guage showes a very small amount of charge,but over time, about a month the batt goes weak.just not sure of cause,mower electrics or gen/voltage reg.this has the kohler single cyl engine. any and all ideas appreciated
Chevy65
12-28-2006 06:44:35
 Re: j d 212 mower in reply to in sticks, 12-27-2006 06:29:43
Problem is most likly the regulator
The back side of the key switch needs to be checked for rust or corrosion or partically melted connector
charging current goes thur key switch before it get to battery
Good Luck
Bob
12-28-2006 09:46:01
 Re: j d 212 mower in reply to Chevy65, 12-28-2006 06:44:35
GOOD advice, Chevy!
Also, he can download and view, (or print) the ENIGNE service manual (in .pdf format) that will cover the stator and rectifier/voltage regulator at the link below:
