brakes
sojono
12-22-2006 14:29:57
does anyone know of a garden tractor that has external brakes for rear wheels if so could i build a small crawler and steer it with the brakes.i think i have it all figured out except the steering thanks sojono.
William Pearson
12-25-2006 16:36:45
 Re: brakes in reply to sojono, 12-22-2006 14:29:57
Wheel Horse, Bolens and Cub Cadet all used a small diameter disc brake set up on the rear axles.
For the crawler I am building the Wheel Horse and Bolens look like the same caliper and pads but the Bolens disc has an off set that might work better for clearences.
What type of garden tractor are you using for a base frame on this project?
On mine a 1973 8hp three speed Unidrive that has 1 inch axles and only four pinion gears will be used so the differential doesn't have to work too hard when steering as opposed to the 10 pinion positraction type or the heavy duty 8 pinion.
One other bit of information I can share is do not make the tracks too long as this will also make for hard steering sice there is too much track to stop/slow down.
Bill in Richmond, Va.
Timberoak 2119
12-24-2006 06:30:40
If yu want a hydro, try the John deere 318 as the had individual rear wheel brakes,
R Bedell
12-22-2006 15:59:59
The Wide Frame Cubs had external Disc Brakes and the model 982 had individual Disc Brakes.
dan kennedy
12-22-2006 15:39:44
the power king tractors have separate rear brakes..
