hydrostatic problem cub cadet 129
J.R. in PA
11-10-2006 04:49:07
my cub will launch into high on the level when i am mowing. example: when i am mowing at a set speed it will go OK for awhile and then it feels like i pushed the lever all the way forward.
please advise
tnx
R Bedell
11-10-2006 05:10:05
 Re: hydrostatic problem cub cadet 129 in reply to J.R. in PA, 11-10-2006 04:49:07
Well, there could be a number of reasons, but the first one I would tackle first, is the "friction" adjustment at the end of the lever shaft. There should be 7 to 10 pounds of drag to prevent the lever from moving on it's own.
J.R. in PA
11-10-2006 06:49:52
 Re: hydrostatic problem cub cadet 129 in reply to R Bedell, 11-10-2006 05:10:05
I think that might be a problem - the reason i say that is because from time to time the lever is very loose to move and other times is very stiff to move. - i will check that
El Toro
11-10-2006 14:02:49
 Re: hydrostatic problem cub cadet 129 in reply to J.R. in PA, 11-10-2006 06:49:52
My Wards tractor did that when it was new. It would come back to neutral without touching the lever. I read the manual and it said to tighten
a bolt or screw beneath the tractor. That fixed the problem. Hal
