bolens w/ snowmobile motor
used to be slow
09-19-2006 18:52:08
Has anyone here done it before? I wanna try it out on a bolens 1050 and i know it can be done with other brands, but i never seen a bolens with one.
any help is appreciated. thanks in advance
slowride>
Too Far Gone
09-19-2006 19:48:39
 Re: bolens w/ snowmobile motor in reply to used to be slowride, but , 09-19-2006 18:52:08
Hi,Im just putting the finishing touches on an old White Garden Tractor.I used a 2 cylinder-399 cc Kohler with 185 lbs of compression per side at 6500 rpm's,and it will cook!Lots of cheap fun!
Mike S
09-20-2006 04:46:21
 Re: bolens w/ snowmobile motor in reply to Too Far Gone, 09-19-2006 19:48:39
How in the world do you get 6500rpm from a Kohler without it blowing up?
landlord7012
09-20-2006 16:00:44
 Re: bolens w/ snowmobile motor in reply to Mike S, 09-20-2006 04:46:21
Mike, As gregg said it is a 2-stroke motor designed for high revs BUT FYI - garden tractor pullers are building the old Kohler cast iron single cylinder 4-strokes to withstand 8000 revs, balanced and blueprinted, aluminum heads, forged cranks and con rods, like the hot rodders do. I saw a Cub Cadet puller that had the cylinder seperate from the crankcase. That one had the head "strapped" down too!!
ll
gregg
09-20-2006 07:28:56
That would be a 2 cycle engine, used in late 60"s-early 70"s snowmobiles.
Too Far Gone
09-20-2006 11:05:46
 Re: bolens w/ snowmobile motor in reply to gregg, 09-20-2006 07:28:56
Yip,Its a 2 stroke,like I said,a lot of cheap fun!
Mike S
09-20-2006 13:55:15
 Re: bolens w/ snowmobile motor in reply to Too Far Gone, 09-20-2006 11:05:46
I saw 2 cylinder not 2 cycle so I was a bit confused. Yes, old 2 cycles can rev up a bit.
