yazoo wisconsin engine
martin reece
09-11-2006 15:57:25
My 2 cylinder wisconsin engine governor isn't working. The engine will not idle down. Any ideas? Thanks in advance, Regards Martin
Steve from New Holland
09-15-2006 04:53:55
 Re: yazoo wisconsin engine in reply to martin reece, 09-11-2006 15:57:25
Yes I do. Of course it could be the govorner, but over the years I have found this problem to be more in the carburetor. What happens is the throttle plate will wear off on the one side and as it wears, that means you can not close down the airhorn like you should be able to. If you remove the govorner rod that goes from the govorner lever to the carburetor and hold it towards idle, will the engine idle down then? If not, you know it is the throttle plate. If it does, then you either need the govorner worked on or the linkage adjusted properly. Steve
