help with kohler 14HP K321
perry in mi
09-03-2006 08:28:39
i just picked up a old kohler 14hp. when i turn it over its spitting the exhaust out of the carburator. i pulled the head, cleaned around the valves and checked to see if both valves are moving. everything looks to be normal. i put it back together & it does the same thing. how do i know if it jumped timeing?. and what would have caused the timing to jump?...
perry in mi
09-03-2006 20:36:00
 Re: how stupid can i be in reply to perry in mi, 09-03-2006 08:28:39
well i racked my brain all afternoon on this one. i bought this motor this morning. it had no generator/starter on it. so being in a hurry i grabed one from a kohler motor off the shelf. come to find out this generator was spinning the motor backwards causeing pressure build up in the engine. i got the right one on it now, and it runs like a champ. i guess i need to slow it down sometimes...thanks again
chevy65
09-03-2006 16:09:36
 Re: help with kohler 14HP K321 in reply to perry in mi, 09-03-2006 08:28:39
Valves cant be seating or damaged
Possible burnt or warped Seat damage Try lapping them to see how tere seting
Make sure it has valve clearance
Bob
09-03-2006 09:02:16
Assuming it was assembled correctly the last time it was apart, it is almost impossible that it has "jumped time".
The intake valve may be leaking.
perry in mi
09-03-2006 10:59:27
 Re: help with kohler 14HP K321 in reply to Bob, 09-03-2006 09:02:16
it seems to be building pressure in the crank case even with the head off, and the crank breather out. rings maybe?.
