help snapper lt12 i have no spark
miah
08-20-2006 12:39:25
ok here is the deal i have no spark and i have a wire off looking for a wiring diagram the wire is a purple + line power at the line getting fule no spark to the plugs though also i am hot starting off the sylonoid due to either a bad key switch or a shorted sylonoid not shure which any help please e-mail me i am realy lost on this one.
Kent of SW MO
08-21-2006 06:55:40
 Re: help snapper lt12 i have no spark in reply to miah, 08-20-2006 12:39:25
What engine do you have? If B&S and you said you had a bad switch, the bad switch may have put 12 volts to the mag coil which will fry the coil. If this is a newer, after 1981, there are no point. The only way to repair is to buy a new coil.
Kent
