Gravely sickle bar
WRHeaney
07-11-1999 11:18:13
The sickle bar on my recently purchased Gravely wouldn't disengage. I found the input shaft had shifted rearward causing that problem. I removed the first casting (marked 31974) and found the nut holding the shaft into the universal had come off. I think I need to disassemble the Ujoint to to put that nut on and I can't get it apart. Took the lock nuts off the pivot bolts (these bolts are cut for a screwdriver) but I can't get the bolts out. Is there a trick to this? What am I missing?
Mark
07-11-1999 19:21:29
 Re: Gravely sickle bar in reply to WRHeaney, 07-11-1999 11:18:13
Try this site,someone there should be able to help you.
