how to refill hydrastatic drive on Gilson tractor
scrounger
12-09-2005 09:59:39
I was plowing with my '72 Gilson/Monty Ward tractor today, and the tire chain caught the oil filter mount and broke a hydraulic line. I replaced the line, but cannot find how to refill the hydrastatic drive with hydraulic oil. There is a few small allen head plugs and one large plug on top of the rear axle unit, under the seat- but it's impossible to fill it through there because it takes so long for the oil to go into those small holes.
How does one refill the hydro drive ? this unit takes 4 quarts. also, is that a bleeder valve down my the oil filter ?
ps- someone remounted/turned the oil filter mount, and had it too close to the tire- I have moved/turned it for clearance so it won't happen again
thanks in advance- need help QUICK- this tractor is now stuck in my driveway !
scrounger
12-20-2005 07:33:05
 Re: how to refill hydrastatic drive on Gilson trac in reply to scrounger, 12-09-2005 09:59:39
to those who may have been following this thread- after removing the large top plug and valve/spring assembly- simply use a LARGE FUNNEL that fits the opening tightly- the funnel I used holds a quart of oil- pour a quart in and walk away- come back 1/2 hour later put another quart in- and so on- capacity is 4 quarts according to manual- no need to jack up the side or remove a tire or bottom plug- the bottom plug is actually a DRAIN PLUG- so if it is removed, the oil will just run out- keep it in
Merry Christmas
jed1950
12-09-2005 21:54:06
e mail me your phone # and I will call and explain how to do
scrounger
12-10-2005 05:19:42
 Re: how to refill hydrastatic drive on Gilson trac in reply to jed1950, 12-09-2005 21:54:06
email me and check your messages- info you asked for has been sent- thanks
